La GeForce GT 730 fue una tarjeta gráfica de NVIDIA, lanzada el 18 de junio de 2014. Construida sobre el proceso de 28 nm y basada en el procesador de gráficos GK208B, en su variante GK208-302-B1, la tarjeta es compatible con DirectX 12. Aunque es compatible con DirectX 12, el nivel de funciones es solo 11_0.
Desplázate por este tema para encontrar el lugar apropiado para este comentario. Luego haz clic en "Añadir comentario a esta publicación" para moverlo.
5 comentarios:
Nina Titi what fan? The one on your PNY GeForce GT 730 graphics card? What have you checked?
@Nina Titi can you check the fan by just applying voltages to it? Do you have a small power supply that you can use for that? Make sure you apply the proper voltage of course. That way you can rule out the fan as the cause.
- de oldturkey03
I am not quite sure on this model but the fan should not spin until it reaches a required temperature.
- de Chris Stables
@imicrosoldering But it never rotates even if the temperature rises greatly, and it does not rotate even though it receives electricity
- de Nina Titi
@oldturkey03 Yes, it does not rotate. I checked its access to electricity and cables, and it rotates heavily once and stops
- de Nina Titi
- de oldturkey03
