Steering wheel and cruise control retrofit help
Hello, has anyone done msfw and cruise control retrofit? I need some help
Im just stuck at this retrofit and cant make it work
Es esta una buena pregunta?
hello.just concluded on my avant 3000tdi quattro from 2008. if you explain the problem better, I should be able to help you. did you install the cruise lever? did you bring the signal wire from the connector behind the levers to the white connector under the water tank of the wipers? did you do the coding?
Fue útil esta respuesta?
So I managed to recognize CC lever in VCDS, its working just fine and I coded it but I didnt know about the wiring part
Can you explain from where to take the wire?
About MSFW it just wont work, coding is accepted and steering wheel light up but not responding to commands
Forgot to mention, cruise control works in vcds but not working while driving
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 21
Todo El Tiempo: 888
