The tablet does not turn on, when plugged keep bootlooping
when i plug it it turn on by itself display the samsung logo then turns off immediately
What could be the problem?
Es esta una buena pregunta?
gateway tech sounds like a power issue. I suggest that you start checking your charger, your charging cord and of course your charging port. Make sure that it is clean, no broken or bend pins and no debris in it. Use a USB ammeter to check how many amps your tablet is trying to "pull" . After that you want to go ahead and change the battery as well. Use something like this video as your guide. Once you did all of this and if you are still having issues, you may need to look deeper and start considering board level checks like suggested here
Of course, while you work on it, create a guide for the rest of us on here. It is not complicated and will be very helpful to the community. https://www.youtube.com/watch?v=j0WMP6vq...
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 255
