Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La HP Pavilion 14m-cd0005dx es una computadora portátil con pantalla táctil diseñada por HP. Tiene una diagonal de 14,0 pulgadas, con una pantalla de resolución de 1366x768 píxeles.
Guidance on Screen replacement
How much more difficult does “touch screen” function make replacement? Are there many more caveats to screen replacement?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@eeandersen it is not much more difficult. You will just have a few more cables and connectors. Essentially the same work. You can download the maintenance and service guide for the HP Pavilion x360 14m-cd0005dx from here It'll guide you through the repair
Fue útil esta respuesta?
Puntuación 1
1 comentario:
@eeandersen, On your laptop the touch screen function is integrated into the LCD display, so there isn't any separate part to deal with; in fact, you can't replace them separately. As @oldturkey03 mentioned, there will be one more connector to route and plug in for the digitizer, but that's it for the difference between replacing your display and a simple LCD replacement.
- de
Añadir tu respuesta
Eric Andersen estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 25
Todo El Tiempo: 325
