Saltar al contenido principal
Un Pathfinder rediseñado salió a la venta a fines de octubre de 2012 como modelo 2013. Al igual que el Pathfinder de segunda generación, una vez más se alejó de un SUV basado en carrocería sobre bastidor y adoptó un diseño unibody.
Preguntas 13 Ver todo
Passenger door handle cord snapped
Does anyone know how to replace the cable for the passenger door so that I can open it from the inside again it appears like a cable is snapped and I don’t really know how to get in there and replace it myself
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
This is a relatively common issue on the forth gen Pathfinder, it's less likely that the cable snapped and more likely that it disconnected from the handle, the point of failure is a C shaped bracket on the interior of the door handle, if that is in fact the issue, the handle assembly will need to be replaced (they're relatively cheap, thankfully).
The process of actually getting to it is slightly more involved.
This is the most accurate video I've seen (some don't show the cable at all) https://youtu.be/B19u9ADWFdw
As a sidenote, it can technically be done without disconecting the control panel, but I wouldn't recommend it.
Hope this helps!
Coco,
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Rachel estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 14
Todo El Tiempo: 470
