Saltar al contenido principal
Lanzado el 20 de septiembre, el móvil abanderado de Apple en 2019 dispone de una pantalla OLED de 5.8", una cámara trasera de triple lente y una autonomía ampliamente mejorada. Es el sucesor del iPhone XS.
I am locked out by a passcode I so not use
I was trying to input my Apple ID; got it wrong again and again and before I knew it I was locked out of my phone entirely. It is demanding a 6 digit passcode. I do not use that so how do I get around this?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
Have you bought the phone second hand or have you had it from new?
- de
Agregar un comentario
2 Respuestas
This apple guide should be able to able to help you out! Are you erasing your data on your iPhone 11 if I may ask? You'll have to put your device in recovery mode if you get locked out too many times by your device passcode or if you forgot.
Fue útil esta respuesta?
Puntuación 0
start with this - https://support.apple.com/en-us/HT204306
if that doesn't work and if you absolutely cannot remember your 6-digit passcode, there's the nuclear option. download and install 3uTools on your PC, boot up the phone and connect it to your PC, use the Flash feature and do an anti-recovery flash.
WARNING - BE AWARE!!!!!!!!
  • this will update you to the latest IOS and return the phone to OOTB condition and you will have to set up your phone again
  • all your data will be lost, i hope you have a recent backup.
  • if you do have an iCloud account connected to the phone it will still be there, hopefully you can remember that password - however, if you can't there are methods via appleid.apple.com or www.icloud.com to recover/reset that password, provided you have access to that account's email and the phone number for two-factor authentication is still good.
Hope this helps. Good luck
Puntuación 0
Añadir tu respuesta
Maureen Bellows estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 73
Ultimos 30 días: 761
Todo El Tiempo: 892
