Saltar al contenido principal
Información de reparación y desmontaje del teléfono inteligente Pixel 7 Pro de Google, lanzado en octubre de 2022. Identificado por el número de modelo GP4BC y GE2AE.
Preguntas 52 Ver todo
Fingerprint sensor not working after screen replacement.
Hello,
I recently replaced my screen and everything seems to be working as expected, except for the fingerprint sensor. If I try to register my digits I get the following error.
Fingerprint setup timed out
Fingerprint enrollment didn't work. Try again or use a different finger.
Can someone help me out with this?
Es esta una buena pregunta?
Puntuación 6
3 comentarios
I found a workaround to this problem, and have posted that workaround on the Google forums here: https://support.google.com/pixelphone/th...
- de
IfThe solution that finally worked was
1. Disable face recognition
2. Go to finger print recognition and It'll work
3. Redo face recognition
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Assuming there is no fault with the parts used, you'll need to run Google's repair tool, it's pretty simple to use but does require a computer running windows.
https://pixelrepair.withgoogle.com/
The program should walk you through it step by step, but essentially, you'll need to download the software, launch your phone into fastboot, and connect it via a sync+charge cable to your computer (the one included with your phone should work, however some third party ones do not)
There's some debate over whether or not this requires a factory reset, and while I don't believe it does, always make sure to backup your phone before doing any kind of debugging.
Coco,
Fue útil esta respuesta?
Puntuación 3
10 comentarios:
I tried this solution and it still does not work. When you try to set up fingerprint, you get error "fingerprint error timed out"
- de
I have the same issue, new "official" screen from ifixit but fingerprint sensor times out immediately. Tried the pixelrepair url, it ran but did not fix the issue.
- de
Install ADB drivers and put usb debugging on. Look on reddit. I did it with the google pxil repair tool. My new screen has now a good sensor again.
- de
Sorry for the late response. I followed Rowdy de Bever's suggestion and it worked! These are the instructions I followed to get it working.
https://www.reddit.com/r/GooglePixel/com...
Hope this helps 🙂
- de
I followed the reddit post that Jordan Martinez posted and it worked like a charm!!
- de
Mostrar 5 comentarios más
Easier solution found after the message "fingerprint set up timed out".
In Face and Fingerprint Unlock
1. Deactivate facial recognition.
2. Go into fingerprint set up. And away you go.
3. Set up facial recognition. Bingo!
Puntuación 0
1 comentario:
Sorry, but it didn't worked for me :(
- de
Añadir tu respuesta
Jordan Martinez estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 48
Ultimos 7 días: 333
Ultimos 30 días: 1,557
Todo El Tiempo: 7,991
