How do I fix camera shake?
The plane collided with a pilot's turn into a pole, and after that, I find a stutter in the camera from time to time, so I hope to find a way to solve this problem since the camera works
Es esta una buena pregunta?
Hi
This one is going to be hard
Most cameras have something called OIS(Optical Image Stabilisation) which is a physical mechanism that helps counter shaking in the camera it self ,the only way of fixing a issue with OIS is to replace the camera itself as it if very fragile and precise
However if possible I would try resetting the device as it could a software issue as some cameras have something called EIS(Electronic Image Stabilisation)
This stabilises the footage through software which could also be your issue
Hopefully this helps
Any questions please ask
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 25
Todo El Tiempo: 457
