Vertical lines on Samsung LCD screen
Hi,
I have a Samsung LCD TV (UE50NU7455). When I turn on the TV it works normally. However after a while (aprox. 15 minutes), vertical lines appear on the screen. First a few on the right side of the screen, but in a few minutes it progresses to the rest of the screen (see photo).
I already performed the following actions:
- reset to factory settings
- update firmware
- removed all connecting devices
- removed back panel and cleaned all connections and connectors (see photo)
- I even bought and installed a new (secondhand) motherboard. However, same problem. After 25 minutes vertical lines came back.
Question to the community. Any other suggestions on how to repair this?
Thanks in advance!
Update (01/12/2023)
@oldturkey03 Thanks for your reply.
I removed the bezel from the tv and teared it down a bit further.
Attached a few more pictures from the LCD driver boards.
Es esta una buena pregunta?
@pieter___ third image top TAB. Is it loose or is it just the light? Any difference to your pictures if you apply some gentle pressure onto the ribbon cable?
- de oldturkey03
