Why is my wifi and bluetooth not working
Why is my wifi and bluetooth not working Why is my wifi and bluetooth not working
Es esta una buena pregunta?
There could be several reasons why your WiFi and Bluetooth are not working on your Samsung Galaxy A10s. Here are a few things you can try to troubleshoot the issue:
Fue útil esta respuesta?
I did factory reset but it still doesnt wrk
Hi I did all but didn't work
After the last Samsung update my wifi and Bluetooth isn't working as well
Same for me, bluetooth and wifi can't be on. when I tried to open it it'll become off again.
Same here to me
الخلل في ايسي بلوتوث والحل استبدال الايسي او تسخينه راح يرجع الجهاز طبيعي
Google translate:
The fault is in the bluetooth eSee, and the solution is to replace the eSee or heat it up, and the device will return to normal
how to replace the esee or heat it up?
Oh my gosh I did everything but still won't connect I'll just chill here and wait for the answer
I am facing the same problem. My Wifi and Bluetooth is no longer working. Is there any Samsung Technician ca help me fix this problem? Thankyou.
I am also facing this issues wifi and Bluetooth devices is not working plz tell me solve the solution plz
Even if I refractory doesn't work
If your WiFi and bluetooth not working it is because of Ic problem you have to change it
If you have WhatsApp installed. Try cleaning WhatsApp data or uninstall WhatsApp. It works fine for me. A10S
It's a hardware issue. The phone's IC has a problem that's why the Bluetooth n WiFi don't work. The technician will demand approximately R250 to R350 to fix it.
No hardware issue this is new update issue.
Not an update issue. My phone has not received an update in years because it an old phone (Galaxy J5 prime). So it is a hardware issue-
My Samsung a10s have the same problem
turn on bluetooth to connect to nearby devices
Still my phone doesn't want to open
Heat ic 300 ⁰c but how can i show the ic
Well I will suggest to do the software update or system updated of your phone. Sometime outdated software version can also cause these kind of issue as well.
You can't update phone without WiFi
Even if I restart don't enable and not op6
I did restart but still is not working
Reset your Wi-Fi router. The location of the reset button depends on what Wi-Fi router you are using but every Wi-Fi router has one.
Thank you, Anthony, but this is not a solution to problem.
Its hardware issue my 2 devices one got resolved heating ic and second one had replaced ic MT6631N
I have an S20+ and a WiFi 6 home network. I'm running the May 2023 update to OneUI 5.1.
Suddenly last night I was unable to connect to my home WiFi network. WiFi worked fine for all my other devices. I did lots of Google searches.... After trying all the obvious simple things (toggling Airplane Mode, Rebooting the phone, etc.), I looked in the S20+ Settings / Developer Options this morning and found "WiFi non-persistent MAC randomization" and turned it ON. WiFi almost instantly started working again on the phone.
I hope this helps others.
Cheers,
Scott.
Ultimas 24 horas: 75
Ultimos 7 días: 376
Ultimos 30 días: 1,753
Todo El Tiempo: 64,295
26 comentarios
Has the phone been dropped or damaged at all?
- de [deleted]
I did factory reset but still not working
- de Luvland Unique
I went in my hardware but my wifi and bluetooth are not listed in and its says unavoidable
What must I do
- de Nicodemus Hangusu
I'm having the same issue on my Samsung Galaxy Note 20 Ultra. After the new update, they both stopped working.
- de Amado Guerrero
Check (verify) the time zone on your phone. I had this problem On the last update and resetting the TIMEZONE corrected the problem.
- de ian.cormie
Mostrar 21 comentarios más
