Still overheating after thermal paste replacement.
I have a mid 2012 MBP 13" and I have noticed that it tends to spike up to 100c almost immediately on any sort of semi-intensive task so I decided to reapply the thermal paste but the highs are still uncomfortably hot. The lows are better dropping from staying in the high 60s to dropping to about 55 at idle. Even if I manually set the fan speed to 100% it still gets hot. The whole die was covered with the paste when I smeared it out and all the mounts are tight. Do these Macs just have bad thermals or is there another underlying issue? I have a 2012 Mac mini with almost identical hardware and even with the stock paste from 2014 it still runs cooler than this MacBook. Thank you.
Es esta una buena pregunta?
7 comentarios
Hi
I have used a 2012 13” and I never really saw it get too hot under heavy use (85deg c or below )
Have you tried a different heatsink to see if that helps the issue?
- de HelloMacOS
@hellomacos I have not tried another heat sink. I can order one to see if that helps but that may be a few weeks. Thank you.
- de Duck
@thequacker
Might be worth a shot!
Also what sort of tasks are you doing on you Mac that cause these temps
- de HelloMacOS
@hellomacos Mainly playing light games such as Roblox and other low end games but sometimes just watching YouTube will get it pretty hot especially with an external monitor (1440p). And mind you this is with fans on full blast and not on the stock fan curve.
- de Duck
@thequacker
Yeah that shouldn’t cause temps that high
Iv seen macs do blender renders and only hit 90 deg c
- de HelloMacOS
Mostrar 2 comentarios más
