Saltar al contenido principal
When I turn on my car it sounds like the engine is hitting something
When i turn on my car the engine sounds like it hitting something but when i go check its nothing after a few minutes it stops it had good oil amd everything is good all the fluids
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi steve,
I did some checking and apparently your car most likely has a timing chain rather than a belt. I used to work at a Datsun dealership where all the cars had timing chains and the first time I heard a loose timing chain I knew exactly what it was; the sound was unmistakable. Over time the chains stretch until the combination of that and the tensioner getting worn down allows enough flex in the chain that it rattles.
You won't be able to tell for sure on your car unless you take off the timing cover and examine the chain. It should be taut with no slack in it at all; if there is, that's most likely the source of the noise you're hearing.
To get any more detail on your problem, it would help a lot if you would add information about the year and engine size of your Grand Am.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
steve estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 13
