Is there a way to fix the headphone jack?
Mine sounds very tinny, it wasn't like this before.
I think the jack is faulty as it sounds a bit better if i press the metal back and the front panel together.
Es esta una buena pregunta?
Hi
You could try cleaning the jack with some isopropyl alcohol and a Qtip/cotton buds
If you decide to try this don’t pour the alcohol into the jack ,dip the cotton bud in it then clean until it looks clean
If that doesn’t work it could need replacing or repairing
Here’s a guide on disassembling the iPod
iPod Touch 3rd Generation Logic Board Replacement
Once disassembled you will need to ether reflow the solder joints or desolder the Jack depending n if your replacing it or not
Here’s a link to the part you may need
https://www.ebay.co.uk/itm/190748878434?...
Hopefully this helps
Any questions please ask
Fue útil esta respuesta?
Thanks, will give cleaning the jack a shot!
@Syamantak Das
Good luck!
I find it’s usually one of the two things
Cleaning usually helps:-)
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 56
