Saltar al contenido principal
The 1998 version is based on the original Beetle but, in comparison with the old model of the vehicle, it is way more spacious and equipped with more advanced features.
Preguntas 16 Ver todo
Where can I find the PCV valve in my beetle?
I got steam coming out the oil cap and I have rough RPM
Update (12/26/2022)
VW Beetle 2.0L 1999
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Although a PCV valve is an inexpensive item to replace and would be worth trying as a first pass, the symptoms you describe can also be attributed to a much more serious issue, that of a blown head gasket. If the PCV valve doesn't fix the problem, you should probably check the compression and run a block check test as your next steps.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
yahya tb estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 115
