Saltar al contenido principal
Información de reparación y desmontaje para el iPhone SE de segunda generación, anunciado y lanzado en abril de 2020.
Preguntas 20 Ver todo
Important battery message after swapping battery.
Hi, I have problem. Few days ago I replace my old battery with new one (ofcourse I swapped BMS to new battery). It didn't show me this message for like 1-2 days and now my phone freaks and display it all the time. Is there any chance fix it? I tried all. Reinstalling software on new and old battery etc. Sorry for my bad english I hope you understand.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario
@maryjusz After swapping the BMS, have you executed the "Activate the battery" step from this video https://youtu.be/zc3-qyX780w ?
If not, I have to say I share your pain, since I haven't either and I am getting the same message.
It's pretty clear to me that the iDevice reports to Apple's servers that it had to activate the BMS before it output any voltage and, if this is reported, the battery is simply revoked.
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@maryjusz, You say you replaced the BMS board from the old battery over to the new one; Did you spot weld the connections or just straight solder them? Did you also cover everything up with good tape or what did you use to encapsulate the BMS board to the battery?
Sometimes, even a very good soldering job isn’t enough :/
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Yes I did it like always I took old BMS solder it to new battery and reset condition on JCID programmer to 100% and 0 charge cycles, next i covered it with tape and plug into phone, first it works good did not show any message, next day it appears. Don't know what I can do to get rid of it. Is there any chance?
- de
Añadir tu respuesta
Mariusz Ogierman estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 295
