Saltar al contenido principal
Dell XPS 15 7590, released in 2019.
Preguntas 6 Ver todo
Bottom of laptop screen has vertical lines?
My laptop started to have these lines on the bottom of the screen. It’s mostly vertical lines that can still show the toolbar sometimes, but it “remembers changes? Like if I leave the cursor there for a while, sometimes the image of the cursor stays even if I moved it already. Sometimes it gets super blurry, but right now, I can still see the toolbar.
It also kind of “reflects” what’s happening above it?
Sorry for the dirty screen. I’ve been using it with an external monitor connected and it works fine, except for like…episodes of flashing?
As I was typing this, it got “blurrier” again.
I also tried what someone posted earlier about pressing on the sides of the screen, and nothing changed.
I was wondering if anyone could tell me what’s wrong with my laptop and if this means I need to get the screen completely replaced or if it’s only a connection that has to be fixed or something?
Thank you so much!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi Dada,
According to the official Dell Service Manual, your computer's display can only be replaced as an entire unit; the LCD and/or LVDS cable is not separately replaceable. It sounds to me like the issue you're seeing is most likely one of those two parts, but either one requires the replacement of the entire display.
Here's a link to the Service Manual that will show you how to replace the display assembly.
XPS 15 Service Manual - iFixit
It's hard to say exactly what replacement screen you need, as there seem to be a few different ones available, but generally it looks like they're running anywhere from about $75 USD for a used one on eBay, on up to about $400 or more for a new replacement part.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Dada estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 574
