Saltar al contenido principal
Una versión más asequible y puramente portátil de la consola de juegos Nintendo Switch, con controladores Joy-Con integrados y una pantalla un poco más pequeña. Lanzado el 20 de septiembre de 2019.
Preguntas 178 Ver todo
power button stopped responding after joystick replacements
Hi! I was replacing the joysticks on my little sisters switch lite, and I've come across an issue. after I replaced the left joystick, everything worked fine, but after the right joystick, the power button refuses to respond(and yes, I have replaced the power and volume buttons
what's going on here? to be clear, I can jump start the system with a multimeter, and the volume buttons do work, just not the power button.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi Bella,
Okay, lets do a little brainstorming here.
The volume/power buttons are connected via a small flex cable going to the circuit board on the left side of the battery (right side if you're looking at it from the back with the case opened up. Given that you said everything worked after replacing the left joystick, let's assume everything was good at that point.
Now to do the right joystick you have to remove the motherboard. The only connection between the motherboard and the daughter card is that somewhat fat flex cable that starts right above the battery connector and goes along the bottom of the battery to the left side daughter card. You do have to disconnect that to remove the motherboard in order to access the right joystick. so my guess is that's where the trouble lies. You'll need to check the cable itself for any kind of damage; it will probably be small if the power button is the only thing being affected. Look along the length of the cable, but especially the contacts at the end where it plugs into the motherboard.
In addition, it's possible one of the pins on the motherboard connector is bent out of place or broken. A bent pin may be able to be straightened with a pair of fine tip tweezers, but a broken one will require the replacement of that connector, a difficult job for an experienced DIY-er, but should be relatively straight-forward for a repair shop.
Look at everything I've mentioned with a magnifying glass and a bright light. If you don't find a problem, go ahead and clean the connector and both ends of the flex cable with 90% or higher isopropyl alcohol (don't use the 70% rubbing alcohol we all have around the house) and reassemble. Check if that's made any difference and let us know what you find.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Bella Marie estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 55
Todo El Tiempo: 823
