Saltar al contenido principal
Un altavoz portátil y resistente al agua para exteriores diseñado por Bose para una cobertura uniforme desde cualquier ángulo. Bluetooth, comandos de voz y conexiones auxiliares permiten múltiples opciones de conexión para hasta 12 horas de uso. Una versión liviana del Bose Soundlink Revolve+.
Preguntas 19 Ver todo
Flat ribbon cable is broken
Is there a possibility to get the ribbon cable between lower circuit board and top circuit board as a spare part?
Es esta una buena pregunta?
Puntuación 1
1 comentario
Did you find one as I'm after one too
- de
Agregar un comentario
1 Respuesta
Solución Elegida
I found this. Search for "30-Pin FFC/FPC Flexible Flat Ribbon Cable Pitch 0.5-1mm 6/10/15/20/25/30/40cm" on eBay.
I ordered the 0.5mm pitch, 25cm long. I get 5 for $1.40. I haven't got it yet. Let me guess, you dropped yours and split the cable?
Fue útil esta respuesta?
Puntuación 0
3 comentarios:
I noticed your original post was for the Revolve (Non-Plus) . Mine was for the Revolve Plus. You can probably find what you need on eBay.
- de
Unfortunately, I have not found one yet. Apparently there are not as a spare part.
- de
Hans, did you read the part number off the cable. This place on eBay will make custom ribbon cables. Just figure out how many pins it is and what length you need. It is probably 0.5 pitch.
- de
Añadir tu respuesta
Hans estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 26
Todo El Tiempo: 507
