How can I fix a loose lightning port?
My lighting port on my phone has become loose and I was wondering if there’s a way to secure the one I currently have or is there a guide to replacing it with a new one?
Es esta una buena pregunta?
Hi Mary,
There are four screws holding the charging port in place inside the phone, but to be honest I've never seen a case where those screws came loose. Rather, what usually happens is that the charging port itself gets damaged or worn, allowing it to move when it shouldn't.
So generally the cure for a loose charging port is to replace it. It's a bit of a job on your phone, as there are a lot of parts that have to be removed to get to it, but it is definitely doable if you have the time and inclination. Unfortunately there doesn't seem to be an iFixit guide for that particular repair on your phone, but there's a French company called SOSav that does have one that will take you step by step through the whole process.
Charge connector iPhone XR repair - Free guide - SOSav
You can, however, get the part you need to do the repair here; although you can use any color, they offer all the varieties to match your phone.
iPhone XR Lightning Connector Assembly
If you're going to tackle this, don't forget the adhesives to glue the screen back on and resecure the battery.
iPhone XR Display Assembly Adhesive
iPhone XR Battery Adhesive Strips
Speaking from experience, I usually buy a couple of the display adhesives; it's all too easy to mess up applying them then you end up waiting while you reorder, which is a pain in the butt.
Good luck with your repair; let us know what you decide and how it goes!
Producto
$29.99
Producto
Producto
$3.99
Fue útil esta respuesta?
I have the same issue. I only used the port to charge the battery, so instead of fixing it I simple changed to using wireless charging.
Ultimas 24 horas: 7
Ultimos 7 días: 58
Ultimos 30 días: 221
Todo El Tiempo: 5,395
