Saltar al contenido principal
Documentación de reparación para el mando DualSense de Sony PlayStation 5. Número de modelo: CFI-ZCT1W
Preguntas 20 Ver todo
Why do all my controllers drift only to the left
I've used three of these controllers now and all three left analogs drift only to the left of the screen. Is it the same for everyone? Do these controllers only drift to the left once they do start drifting? I'm wondering if it's something specific I'm doing or if I could possibly prevent it. I majorly play Fifa, Ratchet, GoW, Wolfenstein.
Regarding the drift itself, I've opened them up and cleaned them several times. I'd appreciate any other suggestions.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Unfortunately this has been a common issue for joysticks since they were first introduced in controllers. The PS5 controller uses the same old potentiometer joystick as prior generations, which wears out quickly and can get dust in the sensor, which causes the drift you are seeing. The only way to fix it permanently is to find a joystick that doesn’t use potentiometers to detect your input. I would check out the King Kong Pro 2, which uses a electromagnetic joystick.
https://www.amazon.com/KingKong-Wireless...
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Oluwaseyi Sule estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 48
Ultimos 30 días: 215
Todo El Tiempo: 3,842
