Saltar al contenido principal
Guías e instrucciones de reparación para el Macbook Pro de 13" con Apple Silicon de segunda generación (chip M2) y pantalla Retina de 13,3". Modelo A2338. Lanzado por primera vez el 15 de julio de 2022 en la WWDC 2022 junto con el Macbook Air M2.
Is it possible to replace the display?
The title says it all. Is it possible to repair the display?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Yes, but it will require either letting Apple fix it or you can do it yourself but! Apple now serializes the display to your logic board so you must use their part as you need access to their calibration tool which will only work with the display they shipped and is a one time access as part of the Apple Self Repair program. Sadly, the newer MacBook M2 systems are not offered yet and this program is only in the states.
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
Thank you for your answer. It looks like I can't repair it myself since I don't know the calibration tool and as you said it's not in the Apple Self-Repair Program.
- de
@Anon User - Sorry Apple is a bit slow on its service options both for the newer M2 systems as well as other countries. If you are set, don’t forget to accept the answer - Thanks!
- de
A replacement display would work just fine. But if you ever take the repaired machine to apple, they would say they cannot “authenticate” the display; so, depending on the genius, they may allow other repairs at their discretion. Important to note that each display may have different color settings because of their batch but that has nothing to do with serialization.
Puntuación 1
Añadir tu respuesta
Anon User estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 848
