Saltar al contenido principal
Repair guides and support for small electric personal space heaters.
Preguntas 14 Ver todo
unmarked component identification help
what is it?
measures 119.8v ac on both sides.....
comes off of the board here:
its normal path from pcb ... usually mounted behind the fan....
wtf?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
That would be a thermistor; basically a resistor whose value changes based on temperature, used to regulate the heat output. Here's a page from DigiKey showing the wide variety of values available.
Glass Encapsulated Diode - Amphenol
Fue útil esta respuesta?
Puntuación 2
1 comentario:
that explains its presence at the fan intake. thank you
- de
Añadir tu respuesta
agnawn uh mous estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 13
