Replacement battery for iPhone SE 1st generation
Can I use iPhone 6s replacement battery in iPhone SE 1st generation?
Es esta una buena pregunta?
No. You cannot. Completely different battery. Why would you want to?
Fue útil esta respuesta?
no its a different connector and different size
I believe you pressed ‘6’ instead of ‘5’. In which case, the answer is sadly the same. The screen and most other components are cross compatible but the battery has a different connector as mentioned above.
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 51
