Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Samsung Galaxy A31 es un dispositivo Android de gama media lanzado por Samsung en abril de 2020. Identificable por los números de modelo SM-A315 (F, F/DS, G/DS y G/DSL).
No network on my phone
I did software update and it removed network on my Samsung galaxy A31 what should I do
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 7
6 comentarios
How to network
- de
4G network how to craet
- de
Phone call problem network
- de
Incoming call receive but call end problem
- de
My phone suddenly connection problem.what can i do.
- de
Mostrar 1 comentario más
Agregar un comentario
1 Respuesta
Respuesta Más Útil
1. Restart your phone
The easiest and often the most effective way to resolve a no service or signal issue on an Android or Samsung phone is to restart it. Doing so will reset any processes that may be interfering with your device's performance. Here's how:
Turn off your device.
Once the phone is off, wait 30 seconds and turn it on.
Check to see if this fixed the issue once it reboots.
2. Turn Airplane Mode on and off
Still having problems? Try to manually connect to your service provider. All you need to do is to turn Airplane Mode on and then back off to re-establish a connection. This resets the device in case it lost connection to a signal tower. To do so, simply pull down from the top of your Home screen to reveal Quick Settings and tap Airplane mode to turn it on, then tap it again to turn it off.
3. Manually select your network providers
It's possible that your device is having trouble finding your network, and you have to select it yourself.
Go to Settings> Connections > Mobile networks > Network operators. A list of network providers should show up. Select yours and see if this fixes your problem.
Regards,
Will
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Vikina Owen Nelly estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 16
Ultimos 30 días: 60
Todo El Tiempo: 3,292
