Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Información sobre el dispositivo y la reparación del sistema de altavoces Behringer Eurolive B212D.
behringer sonic ultramizer 110v transformer
I have this rack behringer sonic ultramizer, and its power input is 110v I need to make it support 220v how to make the input transformer accept the 220v as an input power source
Update (11/14/2022)
Imagen
Imagen
Imagen
Imagen
Imagen
Imagen
Imagen
Es esta una buena pregunta?
Puntuación 1
1 comentario
my rack is behringer sonic ultramizer
- de
Agregar un comentario
1 Respuesta
Solución Elegida
elevenmark your transformers primary should be Black 0V Blue120V Red 230V Secondary are the yellow and orange/brown . The way I would try it, is to connect Black and Red to the 220V line. Disconnect the secondary lines for now, just in case. Then plug it in and measure the voltages on the secondary lines. If the voltages correspond to what they should be, you know how to connect it.
Looking at the way it is connect in your device, all you have to do is to substitute the Red wire for the Blue one. Disconnect your secondaries to make sure.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Yes it works as you said thanks a lot
- de
Añadir tu respuesta
elevenmark estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 296
