Saltar al contenido principal
The Galaxy S7 Edge is the curved-screen variant of Samsung's 2016 flagship phone, the Galaxy S7. Announced February 2016 and released on March 11. Model SM-G935.
Preguntas 20 Ver todo
Lcd swap from one s7 edge to another s7edge
I have 2 galaxy s7 edge g935f, one has a bricked mother board and the other a brocken LCD. I managed to swap the brocken LCD from the bricked mobo one to the one that had the lcd brocken but now the fingerprint doesn't work, and yes it worked fine on the bricked one and yes the brocken screen one had no other issues except for the brocken screen. Any help is appreciated 🙏 thanks
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Hi @impossibledepth,
You don't say explicitly, but it sounds like you separated the LCD from both phones and swapped it over as shown in the Samsung Galaxy S7 Edge Display Assembly Replacement guide, is that correct? As opposed to moving the good motherboard to the other chassis, right? I'm not sure exactly how Samsung does their fingerprint sensor, but on iPhones they're paired to the motherboard, so I'm going with the idea that they are matched; original home button and original motherboard.
Going on that assumption, then you had to disconnect the home button cable in order to remove the motherboard. Have you double-checked that connector? Unplugged it, cleaned it, and checked for any bent or broken pins on the motherboard and the cable?
If that doesn't do the job, you may have to pull the screen back off and check the flex cable for any damage it might have sustained in the process of removing the display.
You've done all the reset/restart/update kind of software fixes first, though, right?
Let us know what you've tried already and give these ideas some thought and let us know what you come up with and we'll see what else we can figure out to help you.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
1fan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 95
