Saltar al contenido principal
Anywhere Mouse MX es un mouse láser lanzado por Logitech en 2009. El mouse se conecta a través de un receptor Logitech Unifying y funciona con dos baterías AA.
Preguntas 6 Ver todo
Mx anywhere mouse side rubber adhesive
Hi there, just trying my luck - my Logitech anywhere 2 mouse is working perfectly, but the rubber adhesive on the side has come off so I tried to glue it back on and reallyt stuffed it up. (Cosmetically) do you repair the adhesive by anychance? Thank you Sean
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
seanhunt1988, I recently repaired a Logitech MX Master (1st gen) and I reused the old “rubber”. I did use isopropyl alcohol and tried to remove some glue, then I glued it back using some strips of very! sticky double sided tape (2mm width), meant for mobile repairs.
That tape is incredibly durable and it’s also very, very thin, which allows for the rubber to place like originally.
The one I use isn’t sold by iFixit, but it’s all over Amazon mobile tape.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
seanhunt1988 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 15
Ultimos 30 días: 31
Todo El Tiempo: 842
