Hi John,
Man, talk about going down the rabbit hole on this one! I wandered some pretty far flung corners of the internet poking around looking for SMD marking codes.
A big problem here is that apparently a lot of manufacturers only use like one or two letters for a part identification, and the rest may well be year, work week and/or lot code.
The most promising lead I found was a PDF for something called Micro3 (company name, maybe?) that gave their package markings. Under the SOT-23 page, a table indicated specific part numbers associated with only the first digit, "B", saying the part number for that is IRLML2803.
01-0041 Version 37, MARKING PACKAGES Model (1)
As you can see in the image, the next two digits are year and week, which would say that the second part, B2Y7 was made in 2002 or 2012 (and depending on how out of date that PDF is, possibly 2022) in work week 25 with a Lot Code of 7. This would indicate that the two parts are actually the same; they just have different manufacturing dates, which would make a certain amount of sense. Unfortunately, the decoding breaks down on the first part, the damaged one, since the work week code on that one is an 8, and according to that PDF file it should be alphabetic (A-Z), so I have no idea what that means; possibly that I've chased that rabbit into a maze and lost it completely, lol.
Anyway, a search for IRLML2803 came up with a part identified as MOSFET MOSFT 30V 1.2A 250mOhm 3.3nC LogLvl on mouser.com, which would make sense for that part, but who knows?
IRLML2803TRPBF Infineon Technologies
That's all I got for ya; dunno if it's going to be a help or just a distraction, but there you go.
Good luck; let us know how it goes!
12 comentarios
@ntec I wonder if you are looking at a voltage regulator vs a transistor. It would explain its location and being in a light would make sense. It would also make sense that it is label as a "U" for some type of "IC" versus "Q" for a transistor. Have you checked for any voltages on the legs? The center pin should be v+
- de oldturkey03
@oldturkey03 with the power off I’m getting 0.5v on the leg.
- de John Nguyen
@ntec any chance you get anything with power on? Does it turn on?
- de oldturkey03
@oldturkey03 I have not checked with power on but I did notice looking closely there was a burn mark on the chip so I removed the chip. The big issue for me is trying to determine what type of chip this is. I still have my old led boards that still work. The pics attached are the newer version of my old led boards that I am trying to get working. Is there any test I can do with my functioning led boards to try and determine the type of chip it is?
- de John Nguyen
@oldturkey03 on my functioning board the chip on that board is labelled B2Y7.
[image|2779948]
- de John Nguyen
Mostrar 7 comentarios más
