Screen looses sesitivity sometimes
Just git this iphones 6s plus, the screen works, somtimes, somtines not, some times restarting helps, somtimes not, screen has no visibke damage, what coukd the problem be?
Es esta una buena pregunta?
Hi @natedawg22
I suggest you take a look at the cable as it seems like that could be an issue. If you don't see any visible damage try to clean the connectors with some isopropyl alcohol.
Fue útil esta respuesta?
Ok, besides this might i have ti replace the screen? Also Would some b7000 glue on the connectors help?
Yes, there is a possibility you might have to replace the screen if there could be an issue with the electronics in the screen or the panel its self. I would not suggest putting glue on the connector as that would make it very difficult, if not impossible to remove incase of the screen needing replacing.
@natedawg22 No, no, no, don't use glue on the connectors; you'll be regretting it the next time you have to remove that cable.
But yeah, if reseating the connector doesn't help then you've almost certainly got some damage to the digitizer and will need to replace the screen.
Ok bet, and what if i dont care about the screen after? Would it help in anyway?
Ok, nevermikd, i read all comments, i will replace the screen, thanks so much guys, thanks fir yiur time
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 49
1 comentario
Oh and i already tried reset and reboot, problems persists
- de Nate dog
