Why would the windshield washer stop working
My windshield wiper fluid is not coming out
Es esta una buena pregunta?
@mamawkathy could be a bad pump, bad hoses or bad spray nozzle. You should here the pump work when you push activate the switch. HAve somebody do it while you listen for it. Or you can disconnect the hose at the spray nozzle and then activate the switch. If water comes out you know the pump works and the issue is your nozzle. If it does not it could be the pump or the power to the pump, check your fuses. GReat information to work on it, can be found on here
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 47
