Saltar al contenido principal
Modelo A1312 / Mediados de 2011 / Procesador Core i5 de 2.7 & 3.1 GHz o Core i7 de 3.4 GHz
Preguntas 687 Ver todo
CPU Fan 0 RPM, Apple Hardware Test Error 4M0T/4/40000002: CPU-0
I bought this iMac used with a broken CPU fan (Macs Fan Control says 0 RPM) and CPU overheats easily . I bought and installed a used CPU fan off Ebay, but it didn't fix anything. I've already tried resetting SMC.
Is it possible for me to tap the CPU fan connector wire into the ODD fan connector or the HDD fan connector? (It's actually an SSD now.) I'm willing to remove the power from the other fans if you think that 1 socket on the logic board shouldn't power 2 fans. Thanks!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
yes!! yes I have this setup right now when the HDD fan connector blew so im using the power from the ODD fan connector to power both fans !
its been like this for nearly a year and never had an issue
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Thanks so much for the reply Teddy. Could you let me know how to do this? I have little knowledge of electricity and soldering, etc.
- de
Añadir tu respuesta
Adrian Phan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 51
