Saltar al contenido principal
Modelo A1989, EMC 3358. Una actualización del diseño existente, con opciones de procesador actualizadas y un cambio en los materiales del teclado. Disponible en plata y gris espacial. Lanzado en mayo de 2019.
Preguntas 105 Ver todo
Mouse/trackpad freezing every 3 seconds for like half second
Hi guys,
I have MBP 2019 and if I am working mouse/trackpad freezing every 3 second for like half second - it's really annoying (specially in Photoshop). Yesterday I made update to macOS Ventura but still same issue.
Thanks for any advice/ideas.
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
Hi
Have you tried reseating and cleaning the trackpad connection on the logicboard
Here’s the guide you will need
Reemplazo del trackpad de MacBook Pro 13" Touch Bar 2019
Also have you tried a wired or wireless mouse to see if the behaviour persists?
If a different mouse works fine and reseating it doesn’t work it could mean that the trackpad or the cable is faulty and needs replacing
It could be a logic board issue but that is quite unlikely but not off the table
Hopefully this helps
Any questions please ask
Fue útil esta respuesta?
Puntuación 1
5 comentarios:
It’s probably motherboard issue as I noticed that one of the USB-C also not working :( I don’t know the history of this MBP but after issue with UCB-C I am done with this because I don’t know what else can be damage.
- de
But thank you for answer :)
- de
@roboscrap
Your most welcome:-)
If you wanted to you could try and fix the logicboard you could but from what you said it seems like CD3215(usb controller chips that has failed,ether that or the usb port itself
But then there the other issue to fix too
But it’s entirely up to you
- de
I will check logic board and will see :) again thanks a lot.
- de
@roboscrap
- de
Añadir tu respuesta
Rob estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 48
