Saltar al contenido principal
Modelo núm. A1367 / Capacidad de 8, 16, 32 o 64 GB
Preguntas 20 Ver todo
Why isn’t my iPod turning on?
I have an iPod touch 4th generation that does not turn on, and the screen will will turn white for as long as I hold down the power button, then go dark again, wondering if there is any easy way to fix it, or if it requires board repair.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Check that you have firm cable connections. Remove any debris from all ports. Try a different charging cable, power adapter, and power source. Don't use an adapter or cable that shows any sign of damage.
Regards,
Will
Fue útil esta respuesta?
Puntuación 3
It's old now, try turning it on with the charger connected. If not, try a new battery.
Puntuación 1
Añadir tu respuesta
someguyidk estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 122
