Saltar al contenido principal
El primer modelo de iPhone, modelo A1203 con 4, 8 o 16 GB de capacidad y una parte posterior de aluminio. La reparación requiere una cantidad significativa de destreza, y puede requerir un poco de soldadura.
Preguntas 221 Ver todo
My iPhone says it is disabled.
My iPhone says "iPhone is disabled connect to iTunes". I have tried everything to get it off this screen, but nothing will work. Even DFU mode won't work because iTunes says the iPhone was previously in DFU mode, but it restarted and is now no longer in DFU mode.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
3 comentarios:
iPhone 1st generation? Probably iTunes doesn’t know what it is anymore.
- de
2001DJ is this your phone? Did you manage your phone with your computer? What version iTunes do you use?
- de
@oldturkey03 I bought the phone from a friend. I tried to restore the memory with iTunes but, it didn't work. I am using the version from the Microsoft Store.
- de
Agregar un comentario
1 Respuesta
Sadly the world has moved on! The cellular network this phone used is no longer active.
The only way to connect is via a Mac or PC which still offers the older versions of iTunes via the special USB to iPhone cable.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
2001 DJ estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 51
