Saltar al contenido principal
La versión más grande del teléfono insignia de Samsung, el Galaxy S8+. Publicado en abril de 2017.
Moisture in charging port, fast charging not working anymore
Ever since I got the moisture in the charging port notification, my fast charging doesn't work anymore. When I plug in the charger it shows fast charging and first then makes a second beeping sound and changes back to cable charge and also my phone doesn't charge when it's switched off anymore, only when it's on. Please what is the issue because I'm about to change the charging port board and I wanna be sure that's the issue so I don't waste money. So please help me out
What can be the issue here as I don't have any money for a new phone right now
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
2 comentarios
Hi
Just adding to the amazing answer from @guardian10
Have you tried cleaning your charging port out with some fine tipped tweezers and some isopropyl alcohol
- de
Yes I have tried cleaning with a tweezer but without alcohol though
Is the alcohol necessary?
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Changing the charging port is likely needed.
Sustitución del Puerto de Carga del Samsung Galaxy S8 Plus
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
Emmanuel Ufot estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 375
