Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
There is a headphone jack stuck in my phone
There is 2.2 mm headphone jack stuck my phones socket.I need to remove it without using glue
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
Hi
You might need to replace your headphone jack depending on how deep it is in but here’s something to try
If you don’t want to use glue you can take it to a reputable repair shop or get a dremel and drill into the middle of the jack(make sure to not let it damage the port though)then once you have a big enough hole in the remaining jack try and get some fine tip tweezers and pull it out
Like I said it might be a good idea to have a professional see it before trying anything serious
Hopefully this helps
Any questions please ask
Fue útil esta respuesta?
Puntuación 2
Open up the phone and push it out from the inside. There's a hole at the end of the jack inside you could put a paperclip in and push the part out.
Puntuación 1
Añadir tu respuesta
Keyaan Hasan Akhtar estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 323
