Saltar al contenido principal
El teléfono inteligente de primera línea de Apple para 2020. Anunciado el 13 de octubre y lanzado el 13 de noviembre, el iPhone 12 Pro Max tiene una pantalla OLED de 6.7 ", un sistema de cámara trasera triple con LiDAR y conectividad 5G. Sucesor del iPhone 11 profesional máx.
Preguntas 20 Ver todo
Guide for replacing lightning port
Hi, I see you sell the part for replacing the lightning port on a 12 pro max, but I can’t find and ifixit guide on the subject, is one available?
I’ve had the phone since launch, it’s now stopped charging unless placed in a specific position, I’ve cleaned the port, tried multiple cables and chargers with no luck, I’ve only ever used MFI certified anker or apple cables. Is there anything else I can try?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario
Other than replacing the iPhone 12 Pro Max Lightning Connector Assembly I can't see any other answer.
- de
Agregar un comentario
4 Respuestas
Respuesta Más Útil
Hi
As @danj had said ,it’s probably time for a new lightning port
However
When you cleaned it did you clean it properly,I suggest you look at it again and use a pair of fine tipped tweezers or a seeing needle to clean it and finish it off with some isopropyl alcohol
Iv seen many lightning ports that claim to have been cleaned but they aren’t cleaned properly
If that doesn’t work it’s time for a new port
Hopefully this helps
Any questions please ask
Fue útil esta respuesta?
Puntuación 2
6 comentarios:
Thank you for your advice!
I did use a pair of fine tipped tweezers but will try some alcohol.
How do I request a guide on how to do this from ifixit? It makes no sense to me that they sell the part but have no guide
- de
@telstar17
Unfortunately I think all you can do is request they make one over on ifixit meta(linked below)
https://meta.ifixit.com/
If it comes to replacing the port I can get you one if you would like but it won’t be from ifixit:-)
- de
I will do that!
I just tried the isopropyl alcohol and fine tipped tweezers and was shocked how much rubbish came out, I’ve never had so much in there before and have always managed to clean it with just tweezers. It seems to be charging much better! Thank you so much for your help!
- de
@telstar17
Your most welcome!
Please let me know if there’s anything else I can help with:-)
- de
Hi, im also facing the issue. Is there any way I can get a charging port fairly cheap?
- de
Mostrar 1 comentario más
As Said By Dan, I don't think any other option exist better try replacing the post before it transcending
Puntuación 1
Hi John,
Glad to hear you got your phone working again without having to replace the charging port!
Just for future reference for you or anyone else looking for a guide, although there isn't one here in iFixit yet, there is a French site called SOSav that does have a very usable guide for replacing the iPhone 12 Pro Max charging port. There are some idiosyncrasies in the translation such as calling flex cables 'tablecloths' and Phillips screws 'cruciform', but outside of those it's very usable.
Charging connector iPhone 12 Pro Max repair - Free guide - SOSav
Puntuación 1
i found a youtube video on how to do it hope this helps
https://www.youtube.com/watch?v=dSy_kjkR...
Puntuación 0
Añadir tu respuesta
John Kelly estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 50
Ultimos 30 días: 200
Todo El Tiempo: 7,406
