What is the Battery volume?
I want to compare with S7 battery volume to see if the batt really is another tech
Es esta una buena pregunta?
Hi, the dimensions of the battery are approximately: 4.7 x 29.2 x 25.4 mm
You can also check out Apple Watch Ultra Battery Replacement for more info.
Fue útil esta respuesta?
Great, thank you! Same efficiency!
@Albert Cor - Energy density is more a factor of chemistry for the given physical space (volume).
Right now we are at a plateau, the current Lithium Ion battery chemistry is the densest we have.
According to the iFixit page for the Apple Watch Ultra, it is a 542 mAh / 2.07 Wh battery
I wasn't asking about capacity, but volume. Are they able to put more capacity in less volume?
What do you mean by volume? Like physical volume?
@jmehnert Yes, thank you!
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 547
