Can I change my iPhone 8 storage from 64GB to 256GB?
Hello , can I physically replace the storage chip (the entire part as and if needed) in my iphone 8 from 64GB to 256 GB? is it possible and will it work?
Es esta una buena pregunta?
Hi
Yes you can but this isn’t recommended
iPhone boards are very densely packed and they are also very thin which means they conduct heat very well
Although this is seen as a good thing on a iPhone that can be quite bad as it can cause things to reflow which can cause shorts
However if you know what you are doing and you are careful it’s possible
You will just need to replace the Nand chip and programme it with the original data from the old one
This can be quite expensive when you consider that the nand is expensive alongside the reprogramming machine and if anything unexpectedly reflows incorrectly it could cause more problems
So in my opinion it’s just worth making a backup and selling your old logicboard and buying a new one just to be in the safe side
Hopefully this helps
Any questions please ask
Fue útil esta respuesta?
Possible with soldering and reprogramming, if you need to ask, you can't do it, find someone else to do it for you.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 68
