Saltar al contenido principal
Lanzado en julio de 2018, el MacBook Pro de 15", modelo A1990, presenta una pantalla de retroiluminación LED de 15.4 pulgadas con tecnología True Tone, TouchID y hasta 6 procesadores Core i9.
Battery flex cable damage?
In replacing my fan, I believe I may have damaged the battery flex cable. I pulled the flex cable out without lifting the seat, and then was able to place back without issue. However, now the computer will only turn on with power cable. If it boots up and I remove the power cable, it immediately dies. With the flex cable reseated, It does recognize the battery, says it’s at 100% and hardware test shows no issues. The computer will also boot up without the flex cable in at all, but will shower an X in the battery, so at least part of the flex cable must be working. I ordered a new flex cable, but what is the likelihood that the logic board itself is damaged from pulling the cable out this way?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
Hey man this literally happened to me today when i replaced the screen how did the repair go after the new install?
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Here's the replacement cable MacBook Pro 15" Retina (Mid 2018-2019) Battery Daughter Board Cable
Imagen de Replace the small flex cable that connects the battery daughter board to the logic board.
Producto
$14.99
Fue útil esta respuesta?
Puntuación 1
this is the exact same thing that happened to my macbook. Any fix?
Puntuación 0
1 comentario:
Replacing the cable of its damaged or if the socket is damaged you can replace them as well but you need good soldering skills, and the needed tools and part.
- de
Añadir tu respuesta
Josh Alinger estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 612
