Saltar al contenido principal
Wi-Fi única variante de la quinta generación de iPad, lanzado en marzo de 2017. Disponible con opciones de almacenamiento de 32 y 128 GB con una pantalla Retina de 9,7 "y un procesador A9 de 64 bits.
Preguntas 96 Ver todo
Can you remove the little circle around the home button?
picture So im repairing my iPad 5 rn and i saw this little plastic ring around my homebutton, i decided to remove it as its just a piece of rubber and plastic, but maybe it served a purpose? lol. Does anyone know if this is bad or can i continue?
Update (08/30/2022)
This, teh left (rubber was first atteched to the back of the plastic one and surrounded the homebutton together.)
Es esta una buena pregunta?
Puntuación 1
3 comentarios
Can you add a picture of the object?
- de
@Traxced
We can’t see the images as they are a comment
You need to add them to the original question
You need to edit the question then add them. :-)
- de
@hellomacos yep i noticed lol, i did it now!
- de
Agregar un comentario
2 Respuestas
Solución Elegida
If you mean the gasket? Then you will likely need this. It helps to mount the button to the display and stabilize it. It also provides some very minimal protection against liquid entry.
Imagen de iPad 5/6/Air 2/mini 4 Home Button Gasket
Producto
$6.99
Fue útil esta respuesta?
Puntuación 5
Hi
From what the photos show that is a gasket
This isn’t necessarily needed but it helps keep dirt out
You could use some light adhesive on it or order a new one
But as I said your iPad should work without it but it’s recommended that it’s there
Hopefully this helps
Any questions please ask
Puntuación 2
Añadir tu respuesta
Traxced estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 90
