How do you check the transmission fluid?
There has to be a way to check my own transmission fluid on a 2015 Murano SV without taking it to the dealer or a mechanic.
Es esta una buena pregunta?
@skweek1 dang that is a beast. Check on here under step 3
"The dipstick is not like the oil dipstick, there is no stick, so you won't be able to check the level.
To remove it, you will need a long skinny flat head screw driver. There is a tab on the dipstick, you need to insert the screwdriver to move the tap while pulling up on the dipstick."
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 19
Ultimos 30 días: 64
Todo El Tiempo: 2,058
