Saltar al contenido principal
This Audi A6 model received a facelift in 2001 for both sedan and Avant versions. The revised A6 sedan featured a new grille design and different headlights, while also being fitted with a wide range of petrol and diesel engine configurations. Most of these powerplants received a boost in power outputs.
Preguntas 7 Ver todo
Why won’t my radio turn even after I buy a new radio?
My radio won’t turn on before it went out completely ot would turn on and off at any time while the car was on. I bought a new radio it still has not worked. How do I fix this??
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
You'll need to verify it is getting power. Check the fuse for the radio. Also check that it is getting power to turn on when ignition is turned on. I want to say yellow wire? Not positive. Check your wiring diagram for the new unit to make sure where power should be coming in at.
- de
Agregar un comentario
1 Respuesta
Ensure the proper fuse(s) are in place and working properly
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Juan hernandez estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 73
