Can an Additional SSD be installed?
Unit has blade ssd already installed. Is it possible to add an additional sata ssd?
Es esta una buena pregunta?
Here's what you'll need:
iMac Intel 21.5" (Late 2012-2019) SSD Upgrade Kit
Here's how to do it:
Reemplazo de Disco duro de iMac Intel 21.5" Retina 4K Display (2017)
Fue útil esta respuesta?
@bigmac98 & @mayer You'll also need the cushions and SATA cable as the blade SSD models won't have these.
@danj If it doesn't already have a drive, will it also need the thermal sensor?
@mayer - The 2.5" dive systems don't need the thermal sensor as long as it supports the newer S.M.A.R.T. Services. All current drives are AOK!
Thanks for the help Mayer! Much appreciated.
@bigmac98 - Don't forget to vote and accept the answer if you're set!
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 46
