Saltar al contenido principal
Variante habilitada para LTE de la quinta generación de iPad, lanzada en marzo de 2017. Disponible con opciones de almacenamiento de 32 y 128 GB con una pantalla Retina de 9.7" y un procesador A9 de 64 bits.
Preguntas 45 Ver todo
Panic (cpu 0 calller) after battery repair
Did a battery repair on iPad 5 Cellular. After customer left with ipad it began to boot loop every 3 minutes. Shows PANIC (CPU 0 CALLER). I have already replaced the charging port but still the same issue.
Any ideas?
Thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Respuesta Más Útil
This is likely some issue with a sensor checking in. This is almost always the case after a battery repair. It’s possible the new battery is defective. Or the battery connector on the board sustained some damage during the repair. The data pins in particular are prone to bend.
Can you post a copy of the full panic report? Or at least screenshots of the first page or so?
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
I have a picture of the panic log below
- de
@store0667 The panic you posted indicates pretty much what I expected. There is a battery sensor (TG0B) which the iPad is not getting communication from. The issue is going to most likely be the new battery, or damage to one of the pins on the battery connector. I would recommend taking the board out to inspect the underside of the battery connector.
- de
Here is some of the Panic log.
Thanks
Puntuación 0
1 comentario:
How did you disconnect the battery before disconnecting the screens? Or what did you use? Does as mentioned before sound like damaged pins on the board. A pain but remove the board completely and take a look for damage.
- de
Añadir tu respuesta
BP 667 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 23
Todo El Tiempo: 720
