Saltar al contenido principal
Casco de RV lanzado el 28 dejunio de 2019
Preguntas 20 Ver todo
Cable part broke off, how to fix
The part that holds the cable for the index broke, and while it works, it sometimes produces static in the left ear. any ideas for fixing it?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
3 Respuestas
Respuesta Más Útil
I think they mean the head strap guide which is mounted to the cable, right behind the left speaker
Mine broke off too, but as its just there to prevent tension on the plug, it might be enough to just tape the cable down so it won't move.
Fue útil esta respuesta?
Puntuación 1
Very easy to replace if I understand correctly,
Part: Valve Index Headset Head Strap Clip
Guide: Reemplazo del clip de la correa de la cabeza del Valve Index Headset
Imagen de Replace a missing head strap clip for a Valve Index Headset.
Producto
Puntuación 0
1 comentario:
This is the incorrect part. The piece that broke off is the cable guide on the left side of the HMD. You can just use tape to fix this, but if you want to fix it, like stock, you have to buy a replacement head strap, as that piece that broke off is a part of the head strap.
Link: Valve Index Headset Head Strap
- de
The same thing happened to mine almost as soon as I got it, since the clip seems to be molded into the arm, you'd have to replace that to fix it properly, but there are clips online that you can 3D print as an alternative, they just clip around the arm.
https://www.thingiverse.com/thing:442425... < a clip I found on thingaverse
If you cant fix it, don't worry, like I said mine broke off really early, and that was in 2019, I just bought my first replacement cable just a few weeks ago, and the damage was past the clip.
Puntuación 0
Añadir tu respuesta
Aneishinobinomono Kage estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 17
Todo El Tiempo: 1,701
