Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Información de reparación y soporte para Dell Precision 5520. Publicado en enero de 2017.
Is it possible to run a Dell Precision 5520 without a primary battery?
The primary battery on my Precision 5520 laptop is not working or at least the BIOS diagnostics think it is not installed. It fails the functional test with error code 2000-0131. Can the laptop still be used without it?
At the moment it does not boot up Windows. I am wondering if I can change the BIOS configuration to ignore the battery?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
I have tried on my own Precision, and I can confirm it will not work. When it recognizes it has no battery, it tries troubleshooting and then shuts down. I haven't found a way around this, but unless you need extra space for something, it should be fine as long as your power brick is ok. I just keep my battery installed, but never unplug my laptop from a power source, so it's basically a desktop. Either get a new battery if you want portability or keep the old battery in and use it as a desktop. Hope this helps.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
James Treacy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 28
Todo El Tiempo: 1,277
