Ford Focus horn failure. Please Help!
I have a Ford Focus Estate, I got cut up at a junction and was unable to show my displeasure in the usual way as the horn stopped working. Any help would be great.
Es esta una buena pregunta?
Fuse brown, solenoid failed. Check the manual for which number fuse it is and check it first. Also check the wires that go to the horn as they can corrode and break off.
Fue útil esta respuesta?
Unfortunately it wasn't that simple, tried all of that and still no noise.
Faulty horn? Test it then if working maybe a faulty horn switch. Put a multimeter on the horn wires and have someone push the horn button. If all else fails then possibly a break in the wire somewhere.
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 22
Todo El Tiempo: 342
