Saltar al contenido principal
The Xiaomi Redmi Note 5 Pro is a mid-range smartphone by Xiaomi released February 2018. It has a 5.99" IPS LCD display, a 12 MP main camera, a 4000 mAh battery, a rear-mounted Fingerprint, and runs on a Snapdragon 636.
Preguntas 20 Ver todo
My phone power button has stopped working!
My Redmi power button has stopped working and is harder to press. it also has occurred with the same with my volume down button in the same location. the device also overheats on charging.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 11
Agregar un comentario
2 Respuestas
Respuesta Más Útil
I don't know if this will help but I had the same problem I think it's just because Xiaomi just wanted to save some money so they cheaped out on the case and buttons I would recommend getting a new case its the easiest solution instead of replacing the buttons and you can even get a new color and if the phone had any scratches it won't have after getting the new case the overheating problem I had to most likely it's just the batteries life has reached its end either that or the charging port is starting to wear lastly te button still doesn't work after getting the new case make sure you clean it if it still doesn't work then your gonna have to replace the buttons flex cable but most of the time its just dirt that's stopping the button from working
Fue útil esta respuesta?
Puntuación 1
Yes it's power button is not working and also it's screen touch is not working properly and it's suck at same time and I will play games than its screen auto rotate 360° it's a big problem 😭😭
Puntuación 0
Añadir tu respuesta
Soheil Sheikh estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 39
Todo El Tiempo: 2,552
