Saltar al contenido principal
La Xbox One X (modelo 1787) es la consola de última generación más moderna de Microsoft, sustituyendo a la Xbox One S. La Xbox One X fue lanzada al mercado el 7 de noviembre de 2017.
Preguntas 20 Ver todo
Bad red artifacting all over the screen
My one X is having terrible artifacting all over the screen with red, is it an HDMI port or something more serious?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
8 comentarios:
@thattechman have you tried a different display? Also, try a different HDMI cable.
- de
ill try that when i get home and ill let you know what happens
- de
In my experience that can be caused by the HDMI port, or one of the EMI filters between the port and the retimer. If a different cable or display doesn't fix the issue, check to see if the port feels loose at all, or if there's any visible damage inside the port. If not, it might be an issue with one of those filters. If you have soldering experience, they are a fairly easy repair, but I'd recommend taking it to a repair shop that offers component level repair if you don't have the equipment/experience for it.
- de
okay so i took it all apart and fiddled around with the port and its not loose at all, i have a hot air station and everything so im gonna try and take a crack at fixing it, where do i start?
- de
@thattechman so it showed red on another display as well and replacing the HDMI cables?
- de
Mostrar 3 comentarios más
Agregar un comentario
1 Respuesta
its the HDMI port or cord
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
well it isnt the cord cause i have the same problem with 3 different ones
- de
I would assume the port then i mean can u send some more pics of the consul
- de
Añadir tu respuesta
John Dragonette estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 34
Todo El Tiempo: 1,770
